METIS engine-fw NEWS
  • Zeldaman
    • Mar 2011
    • 946
  • Gift
    • Mar 2011
    • 2458
    Re: METIS engine-fw NEWS
    Is this an official bulletin? Never heard of it and I can't recall ran into any issues because we yousually update the machines during installation before performing ACC/misc. settings
    • Zeldaman
      • Mar 2011
      • 946
        • 37378
        Most RTBs are sent out to branches only. Those of us with dealers never see them unless someone posts them here.
        • Debs1964
          • Oct 2010
          • 1690
          I have seen that too, but, to be honest, I just do firmware the way I always have done, I have no idea why these instructions have been given either
          There are 10 types of people in this world, those who understand binary maths and those who don't
            • 37378
            The only thing I can think of would to have valid quality configuration to start with. I have been to a couple of calls lately for light copies and print and found that ACC had never been ran. After cleaning the laser shield glasses and running ACC, color quality was where it should be.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              how does printer SP 1103-002 look?? that is the print sp test page that I always look at.............................. color reg, RGB/CMYK Gamut, process black ect.................
              Mystic Crystal Revelations
                • 37378
                Faded before running ACC. Proper after.
                • Zeldaman
                  • Mar 2011
                  • 946
                    • 37378
                    The following has been added to the latest firmware history bulletin dated 12-17-2014 for the engine firmware:
                    At installation (new machine)
                    After power on machine, perform ACC adjustment first before updating the Engine firmware if needed.
                    At PCDU and/or Development Unit Replacement (for any color)
                    Please keep in mind both above cases:
                    1) During the firmware update; do not open or close the Front Cover.
                    2) Do not press the Engine Firmware Update Start Button for 3 seconds after it displays on the panel
                    (See below)
                    It appears that they want ACC to be ran before updating engine firmware when there is a new development unit in the machine.
                    • Polo-022
                      • Sep 2007
                      • 484
                      I tried today to upgrade an MP- C2003SP to the latest fmw.
                      No problem with Engine fmw, but could not load the System/Copy fmw.
                      By pressing the 'Update" button after 3 seconds : two beeps and then nothing.
                      So, i quit procedure...looking for troubles to the next customer!!!
                      • Debs1964
                        • Oct 2010
                        • 1690
                        A lot of the time you get the beeps when you attempt to update, persevere with it, it does eventually start the update. I think it won't start until Java is fully booted as I've noticed this delay only seems to appear on machines where Java is started. You'll find a similar problem if you enter sp mode straight after machine comes to ready, it won't enter system sp straight away. Patience is required with these machines.
                          • 37378
                          Back when the JAVA SD card had to be in the slot used for firmware updates, I got in the habit of stopping JAVA before shutting down to start an update. I still stop it even if I do not need to remove the JAVA SD card.
                          • kyle
                            (See below)
                            What mean ACC?? When i setup METIS, i just update firmware using a package one. its ok using package firmware??
                              • 37378
                              ACC is Auto Color Calibration. User Tools - Maintenance - Auto Color Calibration. Run Copy calibration first, then run all Printer calibrations. It prints a color gray scale which is then place on the platen glass and scanned, Ricoh recommends placing ten sheets of white paper on top before scanning. The scanned results are then compared to the expected results and the scanner gamma settings are adjusted as needed for the Copy calibration and printer processing is adjusted for the Printer calibration. This is to ensure optimum image quality. If it has never been ran, you are most likely getting calls for light copies and prints.
