ricoh mo c2800 mail setup
  • abdelsalam
    • May 2025
    can any body tell me about easy way to setup mail on ricoh mp c2800 to aloow me to scan to mail and also fax to mail
    pleas any body have easy way to make mail for machine help me
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: ricoh mo c2800 mail setup
    You may like to type "scan to email" in the advanced search bar above.
    There are many previous threads on the scan-to-email subject.
    • abdelsalam
      i try to search but didn't find good solution.if you have plz feed me back
      • Elmo
        • Feb 2010
        • 541
        This may help
        I Used To Live To Fix Things Now i Fix Things To Live
        • abdelsalam
          i already try this befor but not working
          1-i need web mail account not use ssl and need it ports also
          2-i need step by stpe setup
          if you try it before plz guide me ,,i need it so urgent
          • Elmo
            • Feb 2010
            • 541
            Web Based mail can be a pain to set up
            u would be better using scan to folder or scan to ftp
            if u search the forum you will find many threads on scan to email using web based mail
              • 36833
              The MP C2800 is too old to support both SSL and internet Fax. There are numerous threads on way to get around the SSL problem. The best way is for the customer to use an email service that does not require SSL. The alternatives are to buy a current model MFP or to set up a server running an email relay software. One other thing, if they are using Outlook 360 or a Microsoft Cloud Exchange, there is a way to set up a non secure relay server through the console interface.
              • 88hawkfan
                • Jun 2014
                • 76
                I have a couple accounts that run outlook 360, can you point me in the right direction of making this work?
                  • 36833
                  I saw them when searching for something else. I did not need them so did not save them. Do some searching.
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    If they are desperate for a scan to email solution they should invest in a small exchange server or upgrade. Otherwise they can look into scan to FTP, SMB or other solution e.g. File Stream.
                    • 88hawkfan
                      • Jun 2014
                      • 76
                      Dammit man, I thought you had the answer tucked away somewhere readily available.
