problem with copy button in ricoh aficio
  • feroo666
    • Dec 2014
    • 23
    [Dead] problem with copy button in ricoh aficio
    iI bought a copy machine, printing richo aficio MP C4500 and appeared where this problem like photos Can anyone help meDSC_0005 (1).JPGDSC_0006 (1).JPG
  • allan
    RTFM!!
    • 5462
    Re: problem with copy button in ricoh aficio
    Does the LED go green or not? Can you print?
    These buttons break a lot i de-solder the proof print switch and replace the start switch.
    Whatever
    • feroo666
      • Dec 2014
      • 23
      No it does not still red
      • skynetto
        • Sep 2012
        • 257
        The machine does not go to ready state:
        1. Check HD. (disconnect it and retry). If it goes to ready replace / format HD. The machine use 2 HD in RAID so you have to check both of them.
        2. If error persist Clear Copy application in SP mode.
        • feroo666
          • Dec 2014
          • 23
          please can you explain how can i disconecct HD or check it
          • redneckstylin
            • Sep 2011
            • 173
            theres a controller on left side toward rear take it out and disconnect sata and power cable for hd... power machine back on you will lose some functions but will eliminate hard drive issues
            • blee
              Technical Trainer
              • 55
              Looks like someone disabled copying through service mode. Go to SP 5-118 and see if its set to 0. If not change the setting to 0 and reboot.
              • rosspt
                • Mar 2012
                • 92
                HDD in a C4500 are IDE not SATA. But that would be my first guess as well. No "ready" text at the top of the copy screen usually points to something hanging the bootup of the machine.
                • mikadonovan
                  • May 2008
                  • 2931
                  Manually select a paper tray with paper in it or put an original into the document feeder to get a green ready light.
                  NEVER ASSUME ANYTHING
                  • feroo666
                    • Dec 2014
                    • 23
                    thanx alot My brother the problem solved
                    107 c then SP 5-118
