Sc 558 error code for ricoh c720
  • jc1print
    • Nov 2014
    • 28
    [Error Code] Sc 558 error code for ricoh c720
    In the manuel, sc 558 it says the oil pump and motor need to be replaced but confused? Can it also be power going to the pumps?
  • anothertech
    • 1769
    Re: Sc 558 error code for ricoh c720
    Goose guide says to check for paper stuck in the oil application unit.
    • jc1print
      • Nov 2014
      • 28
      Originally posted by anothertech
      goose guide says to check for paper stuck in the oil application unit.
      where exactly is the oil application unit or is it called a different name in the service manuel?
      • anothertech
        • 1769
        Oil Application Sub-Unit: Ass'y Part # D016 4480
        In my parts catalog it's Fusing unit 6 item 13
        It is a Sub Ass'y, inside the Fuser Ass'y
        • jc1print
          • Nov 2014
          • 28
          check it out and no paper jam inside and the roller is worn a lil will replace and now go to the next steps checking the oil pumps etc can you tell me what is the cleaner to remove the oil dark oil on the machine and on the walls of the machine please
          • jc1print
            • Nov 2014
            • 28
            also it says to replace the oil supply motor trying to locate that part also
            • anothertech
              • 1769
              Number for to pump is G1784419 Qty 2
              Figure 59 Item 4
              • jc1print
                • Nov 2014
                • 28
                number for to pump is g1784419 qty 2
                figure 59 item 4
                thanks thought so gonna check to make sure power is going there first before i replace anything else
                • anothertech
                  • 1769
                  Hey, sorry, I gave the wrong part number. That number was for the pumps, but for that code the motor number is G1781494
                  Those motors are pretty solid, so for that code i'd take a close look at the oil supply unit, those units cause a lot of problems.
                  Sorry for the mix up.
                  • jc1print
                    • Nov 2014
                    • 28
                    what diagram is that and page please if possible
                    • jc1print
                      • Nov 2014
                      • 28
                      no problem i found the diagram 3 drive section now im just trying to locate where is the drive section to check the if all connections are good
                      • jc1print
                        • Nov 2014
                        • 28
                        i replaced the oil stepper motor do i have to reset the codes anyway to clear problem because the code still comes up and will the error come up if the lines are clogged
