MP C2500 - Undetected Toner problem !!
  • Eslam
    • Jun 2025
    Dear,
    I have a used MP C2500 copier which works fine for a year till now. Lately and suddenly the machine said (please replace cyan toner). I checked the cyan toner, it's only half empty and more than half of it is full.
    I put it back and checked the status, it say (Undetected).
    I tried many times then I bought a new toner, load it into the machine. The machine said (Empty). I tried the old one again and the machine kept saying (Undetected) , the new toner again and the machine kept saying (Empty).
    So please help me (this is the first time I'm changing any toner for this machine). If there's any way to override the toner warning messages and just start printing it would be really helpful.
    Thank you
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP C2500 - Undetected Toner problem !!
    You either have (from most common to rarest):
    Faulty toner pump
    Faulty toner catridge
    Faulty RFID board
    9 / 10 it is the toner pump, we see it all the time.
    • Zaxxon
      • 608
      Change pump, vacuum hose, done.
      Please start you post with brand, model, problem.
      • bob marley
        • Jan 2012
        • 1339
        It could be a defective toner nozzle assembly , pump, RFID board or a blocked pipe
        u can override the loading toner message for now if set sp 3045 to 1 (Not Detect)
        Live for yourself and you will live in vain. Live for others, and you will live again
        • gear13z
          • Sep 2011
          • 68
          just replaced the pump motor...for cyan, and it will save your day...good luck.
          .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
          • Francoi
            • May 2014
            • 4
            Change pump
