Savin c2525
  • CopierChick
    • Aug 2012
    • 85
    Savin c2525
    I was wondering if I can just replace the charge roller assembly that's on the drum unit and if so does anyone have the part number?Also if I have to replace the drums can I modify a black drum to make it work for the colors too? I have a small church that had one donated and was trying to help them out if possible but don't want it to end up being more trouble down the road. Thanks
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Savin c2525
    Use the new B224-2042 BK drums, remove the pin from the connector and file the corner slightly so it matches the connector in the machine (if replacing colour).
    If the machine still has the older B223 drums you will need to throw away the front face and drum stay, and use the new ones that come with the B224. Don't replace the charge roller with an after market one, it isn't worth it.
    You can clean the charge rollers, but they might not last long. Sometimes they do, sometimes not.
      • 37532
      Re: Savin c2525
      If you decide to clean the charge roller, roll a sheet of paper between the charge roller and the cleaning roller. Use only a soft paper towel moistened with water. While you are cleaning the charge roller, check the lube bar. If there is less than 1/8th inch of lube bar left at either end of the bar, it is time to replace the drum unit.
      • khattab.al.masry
        • 212
        Re: Savin c2525
        With my greetings.
