Blank copies Ricoh 1018
  • clemsonfish
    • Oct 2014
    • 27
    went to a machine with an sc320 (Polygonal mirror motor error) I changed the polygon motor and the code went away but now all I get is blank copies...tried internal print, doc feeder, and on the glass
    any sugestions??
  • allan
    RTFM!!
    • 5462
    Re: Blank copies Ricoh 1018
    Sound like the laser light is blocked somehow.
    Whatever
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Don't see this model anymore. The front screw that mounts the Laser Housing is longer than the other 2 screws. Make sure the Laser Housing is in fact sitting flat on its mount. Also, I think this model requires both the Toner Supply Unit and Toner Bottle to be in place to "activate" a shutter on the Laser Housing.
      • clemsonfish
        • Oct 2014
        • 27
        Yes this is an ancient beast...I'm heading back to it tomorrow hopefully i can figure this out
          • 37551
          any sugestions??
          Lets go with a quick question. Did you have the toner tray in when you tested it? I think this is a one of the models that has a shutter that blocks the laser unit when there is not a toner installed.
          • clemsonfish
            • Oct 2014
            • 27
            yes it was in
            • laitang
              • Nov 2012
              • 627
              • clemsonfish
                • Oct 2014
                • 27
                I tried it with the front switch cheated and with the machine completly put back together
                • vargue
                  • Oct 2011
                  • 404
                  sounds like yo used polygon motor from another model 1022/2022/ etc different
                  • clemsonfish
                    • Oct 2014
                    • 27
                    I know its been a while since i updated. I went back out and took the laser unit toner hopper and pcu out nothing was blocking the laser unit. i put it all back together and it went to working fine i guess it was just a fluke.
                    • bob marley
                      • Jan 2012
                      • 1339
                      good news
                      Live for yourself and you will live in vain. Live for others, and you will live again
