ricoh c2550
  • randy0211
    • Aug 2025
    ricoh c2550
    Hi,
    I desperately need help. I finally got the color registration to work after sp 2 111-1. Now things seem ok except that the colors don't align correctly. I tried to do the auto color calibration and It keep asking for paper but won't start printing. Does anyone have any ideas? I already clean and moved almost everything.
    FYI I don't have the Service Manual if anyone can help that would be great.
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: ricoh c2550
    Did you just run Mode A or did you run Mode C first? Run C then A; best to run A twice. If alignment is still correct check that the drums and laser are screwed in.
    You will need the service manual, especially playing around with SP modes.
      • 37560
      Re: ricoh c2550
      Before you run forced line position, you have to make sure that the ID sensors are clean. A dirty ID sensor assembly can throw the position off. You may also be having problems with the ITB slipping in it is getting old. I agree with Ruben, get a service manual.
      • randy0211
        Re: ricoh c2550
        Thanks so much for the info guys! I just started to have the original problem again. Color Registration cannot be performed. and 2111-A is failing. I don't know what else to try. Can anyone point me in the direction of the Service Manual?
        • turbojetboy
          • Aug 2009
          • 279
          Re: ricoh c2550
          Re-input all non default settings. The problems you have sound suspiciously like the machine has been subject to a memory clear. You should dig out the birth cert and go over all the values.
          • Gary Bowen
            Bowdog
            • Mar 2008
            • 250
            Re: ricoh c2550
            There is a site: www.justmanuals.us that has a number of free manuals. I have not used this particular site but the parts and service manual for the C2550 show as being available on their site.
            I would try running the "acc calibration" page to see if all 4 colours are there and of similar laydown - if 1 of the colours is too lite it will throw of the MUSIC adjustment and cause it to fail.
            • bpkopi
              Do the forced process control (SP3-011-001) or supply some
              toner (SP3-015-xxx).
              • Iowatech
                Not a service manager
                • 3930
                Re: ricoh c2550
                Originally posted by randy0211
                Hi,
                I'm going to base my reply on the underlined portion of your original post.
                The machine needs to print the calibration patterns so that the long side of the paper of the default paper size in your area can be placed next to document guide on the left side of the platen glass.
                For example, here in the U.S. the default paper size is "Letter" size, which has the dimensions of eight and a half inches by eleven inches. So the calibration pattern needs to be correctly aligned with the eleven inch long side of the paper, and the eleven inch long side of the paper then needs to be aligned with the document guide on the left hand side of the platen glass. The machine won't print the patterns if that is not the case.
                I'm sorry if I got this wrong.
                On a lighter note, if you know what you are doing in service mode, there should be some useful adjustments in SP5 for this. If you don't know, I'd recommend you stay away from that, it has quite possibly led me to some of the most boring and frustrating hours I've ever spent working on machines (heh, that's my diploma from the School of Hard Knocks for the course "Why Using The Memory Clear SP Mode Is A Really Stupid Idea Only Used By Morons, You Fool.).
                • teebee1234
                  • Jul 2008
                  • 1670
                  Re: ricoh c2550
                  If the density of any of the colors is too light, you can have this issue. Along with what the others have stated in regards to clean ID sensors and the ITB, you should change out the pcu's and developers and start fresh.
                  • Zeldaman
                    • Mar 2011
                    • 946
                    Re: ricoh c2550
                    Hi there!
                    Important: when you clean the ID-sensors, remove the bracket (see photo) and clean it. Otherwise the tonerdust will sit again on the ID-sensors. By the way RICOH recommended to use a dampened clothe (water, no alcohol) to clean the ID-sensors, cause of static problems.
                    Greetings...
                    • Zeldaman
                      • Mar 2011
                      • 946
                      • wyo19
                        • Nov 2012
                        • 51
                        Re: ricoh c2550
                        Hi,
                        Just a thought, my first questions are
                        1) updated firmware
                        2) PCU last 60K is it within specs. When was the last PM done.
                        3) are there any service codes? any in the SC400 and above.
                        • ariosz17
                          • May 2016
                          • 8
                          Re: ricoh c2550
                          Hey guys, maybe someone can help me. A customer had their machine plugged into the wall and with faulty wiring fried the board. I replaced it but when you connect the ethernet port the lights turn on like normal BUT it doesnt get a connection. Am i missing something? Thanks for the help.
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Re: ricoh c2550
                            Can you print a config page and scan it here? Are you trying to get a connection via DHCP or static? Which board got toasted?
                            Hit it.
                            • wyo19
                              • Nov 2012
                              • 51
                              Re: ricoh c2550
                              If you have a 4 or more port switch try that, wall to switch, switch to copier....
