Ricoh Aficio 6500 SC 495
  • powshar
    • Jun 2011
    • 52
    We have a Ricoh Aficio 6500 in the field that has been eating our lunch showing a SC495. We have cleaned the sensors, taken the Toner recycling unit apart, etc., and it still keeps popping this code. Any ideas out there? It would be much appreciated!
  • Gamut
    • 216
    Re: Ricoh Aficio 6500 SC 495
    Just google copytechnet sc495 ricoh, or search this site there is a thread with a graphic showing sensor that causes this.......
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      try to cleaned the sloping toner recyling coil from the transfer unit, this may clogged and the senson throws a SC 495... SC 590 is from the vertical coil from developing unit... Good Luck Sir.
      fix the customer first then fix the machine... its simple and makes life more easy.
      • Zaxxon
        • 608
        Aaaaand update firmware to prevent this in the furure.
        Please start you post with brand, model, problem.
        • khattab.al.masry
          • 212
          The following figure attached in pdf. file is related to title No.55 (TONER COLLECTION (B246/B248/B250/B253)) as in parts catalog manual.
          I faced the same problem so I attached the following pdf. file hoping to help you.
          with my greetings.
          • allan
            RTFM!!
            • 5459
            Very good machine pity about the fuser and the leaky developer bushings. There is no sensor control on the drum cleaning toner recycling only gears that brake. Had that code before . There is that funny shaft gismo at the back of the machine behind the dev tank to transport toner this sensors could be the problem (dirty) as well or there is a blockage. Wish Ricoh could give sub codes for a SC495.
            Whatever
              • 36810
              There is no need for any sub codes. Reference imaginemoko's post and khattab.al.masry pdf file, SC495 means that the signal pulses from from sensor 31 are either not present or are too far apart. The tube coming down in back of the development tank will give an SC 590 generated by the sensor at the top of that tube. SC 495 is also caused by the main motor running slow due to a bad motor or too much load. See the attached file, Page 6-61 from the service manual. there is one error on this page. Coil C is not driven by the toner collection. Coil C is driven by te main motor.
              Waste toner collection.pdf
              One other thing that I have encountered is that is the toner overflow switch fails, the waste tone bottle will fill up and backup into the waste toner pump causing Coil C to clog.
              • allan
                RTFM!!
                • 5459
                Burned by slimsob . I do apologise. Forgot about sc590 i had a AF2090/MP9000 in mind when i replied to that. Please disregard that post.
                Whatever
