MPC305 airprint
  • GeorgeBest
    • Jul 2009
    • 526
    MPC305 airprint
    Not much experience on this machine, but customer asked
    if he could print using the airprint function with his Ipad/Iphone.
    Is this possible and do I need a wireless Lan option for it ?
    Thanks in advance
  • Tehno copy
    • Jan 2015
    • 3
    Re: MPC305 airprint
    I think that you do not need a wireless Lan, but machine must be conected with a lan cable to a wireless router.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: MPC305 airprint
      If the customer has a dedicated server, or PC that is always on, they can install AirPrint for Windows and print to any copier or printer from their phone or iPad.
      See: How to enable AirPrint for Windows
      • allan
        RTFM!!
        • 5462
        Re: MPC305 airprint
        Ruben have you done this before? I would really like to install that to test.
        Thanks for the info.
        Whatever
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: MPC305 airprint
          Ricoh has just released frimwar for airprint. It is only available on the NEW Color '03 series machines...............................
          Mystic Crystal Revelations
          • allan
            RTFM!!
            • 5462
            Re: MPC305 airprint
            Same with Konica Minolta e-series
            Whatever
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Re: MPC305 airprint
              It's a common misconception that all AirPrint is wireless, that is not the case.
              Case in point: I have a Brother laser printer at home that supports AirPrint, yet offers no wireless option for my model.
              I connected it to an Ethernet port on my wireless router, and can print from our iPads with no issue at all.
              Different brand, same idea.
              • Tonerbomb
                • Feb 2005
                • 2589
                Re: MPC305 airprint
                You would be correct KenB. It allows apple devices to print to devices that don't necessarily support post script printing, but support Airprint.......
                As I stated Ricoh only released frimwar for the '03's, they are not giving away Ricoh wireless options......................
                • StrippedScrew
                  • Jul 2012
                  • 58
                  Re: MPC305 airprint
                  Use the Ricoh Smart Device print and scan app, android and mac compatible, works on all newer machines.
                  • mikedci
                    • Jul 2010
                    • 227
                    Re: MPC305 airprint
                    Airprint supported machines. About AirPrint - Apple Support
                    The MP C305 will need printer firmware > 1.06 D1175432F
                    Network Support Firmware v12.27 (D1175430G) or later
                    and PDF v1.01 (D1175436A) or later
                    • collme
                      Ricoh tech
                      • 221
                      Re: MPC305 airprint
                      Once new firmware has been installed, you will need to go into user tools, admin settings and then certificates. activate new certificate and follow the screen directions. reboot and AirPrint will work as long as the Apple device is connected to the server by Wifi, Machine will be wired connection to the network and the whole thing works via the network.
