Ricoh 1035
  • tcypy1961
    • 773
    Ricoh 1035
    can't get rid of SC 352 codes; replaced ID sensor twice;2nd ID sensor I replaced today allowed me to get SP3001 to set without error code; however after about 20 copies SC 304 followed by SC 352 came up. Another thing I notice is when copier is shut down the powered back up copies are light and SP 2001 has changed. Could this be an NVRAM problem???
    Thanks!!!
    • 37538
    Re: Ricoh 1035
    I think SC 304 is the key to the problem. Both codes relate to drum charge, possible over toning and possible coated development (mag) roller. If you do not currently have a copy of Goose's Guide, download it and follow the trouble shooting steps it lists.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: Ricoh 1035
      Kill it and replace it!!!!!!!!!!!!!!!!!!!!!!!!!!
      Mystic Crystal Revelations
      • bob marley
        • Jan 2012
        • 1339
        Re: Ricoh 1035
        Check the charge roller , I think bushings are dirty and preventing it from moving
        Live for yourself and you will live in vain. Live for others, and you will live again
        • Athlontini
          • Jun 2012
          • 269
          Re: Ricoh 1035
          ^^This was what worked for me the last time I saw an SC304.
          • Richariri
            • Dec 2013
            • 163
            Re: Ricoh 1035
            I keep getting 304 on an MP4000, i cleaned the charge roller, contacts and bushings then developer and mag roller were replaced. cleaned ID sensor and reinitialised.
            Still get the SC304 coming in on @remote, but no issues on CQ.
            So yer, we've abandoned hope until the CQ goes downhill.
