3260 fuser belt
  • vargue
    • Oct 2011
    • 404
    [Dead] 3260 fuser belt
    hi fellas i want fuser belt for aficio3260c and is missing in my country please . used or new brand i wait ours answers
  • sandmanmac
    • 3979
    Re: 3260 fuser belt
    To the best of my knowledge no countries sell fuser belts for this machine, because it uses Heat and pressure rollers - no belts
    So what is it that you're actually looking for?
    • teebee1234
      • Jul 2008
      • 1670
      Re: 3260 fuser belt
      Actually, it does use a belt that goes around a fusing roller and an aluminum tube. The fusing roller is the one that tends to rupture like a hot dog in the microwave frequently, which then takes out the belt.
      Vargue, you should be posting your request here > http://www.copytechnet.com/forums/fo...ade-or-wanted/
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        Re: 3260 fuser belt
        D014 4090 Fusing Belt if its MP C6000.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • sandmanmac
          • 3979
          Re: 3260 fuser belt
          Oops! My bad, and my apologies to Vargue.
          I was relying on memory (BIG mistake), and only ever worked on one of these a couple of times. I Had no recollection of the fuser belt
