MPC 2500, "grease stains" on prints
  • steele
    • May 2012
    • 48
    [Misc] MPC 2500, "grease stains" on prints
    Hi, I have strange issue in Ricoh MPC 2500. Only on black text prints i have greasy light background around few letters, only in one line. I've change dev unit and PCU. No changes. On picture line with "-141 B4 SEF"
  • freginold
    • Sep 2010
    • 102
    Re: MPC 2500, "grease stains" on prints
    Is it always on the same line? I've seen that happen on the big machines. The drum drive gears were dirty, causing the image to skip a little. Try cleaning the drum drive section, see if that helps.
    Config page instructions for copiers, printers, & fax machines
    • copier tech
      • 8169
      Also check your fuser, check theres no toner build up etc in the position of your blurr
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        can we try to print a test pattern full coverage of black if it will appear. try also cleaning the laser target glass Sir.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • steele
          • May 2012
          • 48
          It is always on the same line and only when i'm printing text. It does not occur when copying (I tried to copy a newspaper - no marks). Fuser was also replaced. I'll try to clean the laser.
          • sandmanmac
            • 3981
            This looks a lot like an issue I had on one of these machines a while ago where the oil roller had a flat spot, and wasn't turning. I assume that it was causing a bit of drag when the page first entered the fuser.
            Try testing the machine with the cleaning assy removed
            • Zaxxon
              • 608
              I've got a similar blurred image line on a MP 6500 it was the laser shield glass that was dirty, it wasn't easy to see the dirt cause it was small toner particles. Cleaned it with alcohol, wupti the blurriness was gone.
              Please start you post with brand, model, problem.
