Ricoh 2238C Fuser Gears...Help Please...
  • the tenor man
    • Oct 2007
    • 24
    Hello all,
    I have a couple of Ricoh 2238C boxes and they are workhorses for me.
    I have a bit of a problem with two small gears that I can't seem to find the part numbers. I've looked in the parts book for the fuser breakdown but I can't seem to locate these two gears.
    These gears seem to be the weak point of the fuser...if I could just replace these two gears, I could get a lot more mileage out of an otherwise sturdy unit.
    I have attached a photo with the gears circled. If anyone could help me with the part numbers, I would appreciate it!
    Many thanks and best regards,
    The Tenor Man
    • 37439
    Re: Ricoh 2238C Fuser Gears...Help Please...
    You might want to check to see if they are the same as the 2 gears on the front of the oil supply rollers.
    G0801495 Gear Oil Supply Roller #2 Front
    G0801494 Gear Oil Supply Roller #1
    • the tenor man
      • Oct 2007
      • 24
      Slimslob,
      Thanks for your reply.
      I did check those gears but I don't think that they will interchange....
      The gears that I'm looking for are slightly helical....
      Many thanks....
      The Tenor Man
      • logrady2331
        • Feb 2011
        • 301
        When I see these gears go bad I just put the whole fuser in. It's about 65.00 dollars. Not worth the labor to change them, especially since the thermistors won't be far behind.
          • 37439
          I seem to remember that we always replaced the entire fusing unit when the fusing belts failed. It was less expensive than the parts and labor. The only gears I ever had go bad was the drive input gear. When we had to replace one because of a belt failure, we would harvest for gears.
