MPC2800 Ricoh Drum Modifications
  • copier tech
    • 8174
    My company is stocking MPC2800 black drums as apparently they can be modified to fit mpc4500 & mpc3002 series for both black & colour because they are cheaper!?
    I have found some info on this, but has anyone got any other info on what exactly I need to do to in order to make these drums fit each machine!?
    Many thanks.
  • skynetto
    • Sep 2012
    • 257
    Re: MPC2800 Ricoh Drum Modifications
    Please check on the forum. There is a chart somewhere with all the modifications needed and what to apply when.
    • marcobill
      • Jan 2013
      • 4
      Many thanks.
      DRUM SHEET VERSION 35.2.pdfHello copieur tech you have to see that attachment
      • copier tech
        • 8174
        Thanks, so to fit an mpc2800 black drum to an mpc5502 black all I do is file the connector down? No wires to sawp?
        • marcobill
          • Jan 2013
          • 4
          yes swapping see new file sorry
          • NeoMatrix
            Senior Tech.
            • 3513
            Lagonda has a drawing to build a tool for removing the rear metal tab on the main frame of the later models.
            You may like to search the forum for the tool mod.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              I haven't had any luck fitting a B2232042 black drum to an 02 series as a black drum yet...that lube bar recess seems to stop the 2042 from fitting properly.
              And judging from the cheat sheet you still have to use the 2250 genuine drum?
              • cooljeb
                • Jan 2015
                • 18
                Hi we use the PCU from SPC811 And SPC820 See Attachment
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  I believe there is an updated version file already on this thread.
                  See two or three previous threads back. You may need to log in to download it.
