SC361 and SC543, SC544
  • Mip
    • May 2025
    [Error Code] SC361 and SC543, SC544
    Do you have information on how to solve a SC361 problem on this machine ?
    Thanks a lot,
    Michel
  • Zeldaman
    • Mar 2011
    • 946
    Re: SC361 and SC543, SC544
    Hi there!
    What type of machine???? Discwasher,refrigriator?
    Greetings...
      • 37107
      Is that a SC 361 or SC 561?
      • turbojetboy
        • Aug 2009
        • 279
        Originally posted by Mip
        Thanks a lot,
        Michel
        Top notch first post......
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          Frigidaire, whirlpool, ricoh, konica, kenmoore??????????????????
          Mystic Crystal Revelations
          • NeoMatrix
            Senior Tech.
            • 3514
            MACHINE /REQUEST/FAULT/ERROR:
            <add make,model,meter reading>
            STEPS TO RESOLVE ISSUE :
            < add details>
            CURRENT CONDITION/STATE :
            <add better,worse,no change,moved,attach sample>
            ADVANCED SEARCH:
            < add manual,CTN,google>
            • Mip
              Oooops, thought i mentionned it : it's a RICOH MPC2500
              • laitang
                • Nov 2012
                • 627
                SC361: Magenta TD sensor (Vt high) error .
                Symptom
                -􀂃 The Vt value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 4.7V) with SP3020-002 for twenty counts.
                􀂃- The [Vt - Vtref] value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 5.0V) with SP3020-001.
                Possible Cause
                1. Magenta TD sensor disconnected
                2. Harness between TD sensor and PCU defective
                3. Defective TD sensor.
                Troubleshooting Procedures
                1. Check the black, magenta, cyan, or yellow TD sensor connector and harness between the TD sensor and PCU for damage.
                2. Check the drawer connector.
                3. Replace the defective PCU.
                • bob marley
                  • Jan 2012
                  • 1339
                  1 -Sc 343Possible CauseSc 544Possible Cause
                  Live for yourself and you will live in vain. Live for others, and you will live again
                  • NeoMatrix
                    Senior Tech.
                    • 3514
                    Fuser front or rear side fan had an issue of slow operation in this model. Replace the fan.
                    HTH
