I've Never been able to setup a scan to file on a Ricoh copier...
  • mrwho
    Major Asshole!
    • 4299
    Re: I've Never been able to setup a scan to file on a Ricoh copier...
    Originally posted by copyaction
    I had one last week on windows 7 we had to turn off password protected sharing
    I believe that only works if the pc is not in a domain; if it is, there's no such option, I think.
    Mascan42
    Ibid
    • Elmo
      • Feb 2010
      • 541
      This check list may help also ensure you share the folder with everbody
      I Used To Live To Fix Things Now i Fix Things To Live
      • Foo
        • Nov 2009
        • 199
        Thanks I'll keep a copy of this in my tablet for use in the field too.
        Jeff
        • apn82163
          • Apr 2013
          • 4
          #19
          Have you tried setting up an FTP scan? I use a FTP utility from Konica Minolta that seems to work as a great substitute when I can't get SMB to work. Let me know if you're interested in trying it and I can email it to you with setup instructions.
