Ricoh MP C7501 Off colors
  • tibbs
    • Aug 2008
    • 225
    Hello friends, I have a Ricoh MP C7501, the colors are of and am not sure what to do with this machine.
    I have run the calibration a couple of times and the same thing. Am not sure whether I should change all the pcu.
    Can anyone help. This machine is on a ship.
    Thanks.
  • nichlaus
    Re: Ricoh MP C7501 Off colors
    are you using an external print server?...fiery or creo? or printing direct from your pc/mac.
    check ur ID Sensors, they are dirty. check for scattered toners inside the machine, those can make ur sensors readings incoorect. check if u got a SC4xx is/are registered in SC history (SP7403)
    cheers
    • Iowatech
      Not a service manager
      • 3930
      If possible, could you provide an picture of the print defect? It would help with the diagnosis.
      Sorry, some of us need visual input to give correct information, and as we can't physically see your machine and what it is doing it would help if you could be our eyes.
      • Zaxxon
        • 608
        Thanks.
        Change all PCU's!!! You will get fired....
        Please start you post with brand, model, problem.
        • digicor
          • Jul 2008
          • 1159
          Whats the meter on the DV? if its over, change it, i would change it all at once, and run your acc then run your calibration, i heard if you run user calibration more than a couple times it will affect the density of the colors
            • 37628
            Ricoh has put out a number of bulletins on this beast concerning light image and toner scattering. If you do not have them, download them and apply all the recommended adjustments. After you have finished all the adjustments recommended by Ricoh bulletins, make the adjustments found in the attached. Service Program (SP) Settings.pdf
            • bob marley
              • Jan 2012
              • 1339
              Ha Ha Ha .Zaxxon .today I was tired after a tough and boring day , don't think I even smile
              Live for yourself and you will live in vain. Live for others, and you will live again
