Hi , suddenly the pro 1106 ADF start to shift originals , the shift is not the same also there are skew . the shift happened on the original glass , please advise
1106 ADF shift originals
Re: 1106 ADF shift originals
You may have a problem with uneven friction between the ADF transport belt and the paper. Clean or replace the belt.
The belt pressure rollers might be deteriorating and not placing equal pressure across the width the ADF transport belt. Inspect and replace if necessary.
There may also be spots on the glass where the paper does not slide smoothly. Clean it and then put a few drops of silicon oil on the glass and, using a soft paper towel, spread it over the entire glass. This will leave a thin, one or two molecules, layer of silicon on the glass and fill in small scratches. A number of manufacturers used to say to do this when installing a document feeder on old analog copiers.Comment
