1106 ADF shift originals
  • aaahmmm
    • Aug 2009
    • 103
    Hi , suddenly the pro 1106 ADF start to shift originals , the shift is not the same also there are skew . the shift happened on the original glass , please advise
  • Iowatech
    Not a service manager
    • 3930
    Re: 1106 ADF shift originals
    Well, I'd guess the problem was caused by static electricity on the glass. At least if the problem gets worse the more originals you feed through the document feeder (if that is the case, let us know).
    • aaahmmm
      • Aug 2009
      • 103
      no it starts shift from the first page , but i see that the shift is less when i do double side scan
        • 37484
        You may have a problem with uneven friction between the ADF transport belt and the paper. Clean or replace the belt.
        The belt pressure rollers might be deteriorating and not placing equal pressure across the width the ADF transport belt. Inspect and replace if necessary.
        There may also be spots on the glass where the paper does not slide smoothly. Clean it and then put a few drops of silicon oil on the glass and, using a soft paper towel, spread it over the entire glass. This will leave a thin, one or two molecules, layer of silicon on the glass and fill in small scratches. A number of manufacturers used to say to do this when installing a document feeder on old analog copiers.
