MP 171 network card Problems.
  • tibbs
    • Aug 2008
    • 225
    mfd network interface is faulty and flashin red led light (with or without network cable) tried remotely but no access to access codes to change the settings.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP 171 network card Problems.
    And what have you tried so far? Are you sure it is faulty and you haven't just not setup the interface settings correctly? If you think it is faulty then you should replace the controller.
    • Iowatech
      Not a service manager
      • 3930
      A red light on the printer button could be the application you are printing from needs a size of paper that is not in the machine. The print job will be at least partially stored in the machine's memory, which is why the red light appears whether the network cable is plugged in or not.
      You should check that.
        • 37488
        Are you referring to the red light next to the Printer Function button on the control panel or the one next to the network connector? If it is the one next to the network connector, clear the following:
        Printer Application - SP5801-008
        Scanner Application - SP5801-009
        Web Service/Network Application - SP5801-010
        NCS - SP5801-011
        You will have to reenter all your network settings. If this does not correct the problem, then the controller board will need to be replaced.
        If it only does it when the network cable is plugged in, there is a problem with the switch that it is connected to.
        • sandmanmac
          • 3981
          There is no red light on the network interface. There's orange and/or green.
          If you're talking about the tiny little red led you can see inside - it always flashes red
          So how about being a little more specific as to what you are actually talking about???
          And what 'access codes' ?
          Side note: Why the tiny font. Are you shy or something?
          • Sashko
            • Oct 2009
            • 110
            What is model name of your device - LN (GDI) or SPF (GW)?
            • tibbs
              • Aug 2008
              • 225
              This machine is on a ship and I can only get to it when the ship is in port. The problem is the orange light stays on, and when they send a print it does nothing. My guess is that the network controller does not work. Am not sure how to clear this in sp mode.
              • Bantams
                • Jun 2012
                • 603
                Probably more likely its not connected to the network either the cable is broken or it just isn't plugged in the Orange light is always on the green one doesn't come on if its not connected
                • qbert69
                  • Mar 2013
                  • 1152
                  * and # keys held down for about 10 seconds in copy mode should clear the memory and do a soft restart!
                  REACH FOR THE STARS!!!
                  Konica Minolta Planetariums!
