2238c Black?
  • zflash7
    • Jun 2012
    • 39
    2238c Black?
    Hi,
    After I replaced the drum drive motor and the gears, a few copies later........
    The black toner will not fill up the development unit. First sc393-01 came up development error.
    Then I did a reset and then sc386 gamma error, I did another reset of the black toner then Toner supply mechanism came up.
    Also my process control self check sp3-975-001 comes up at 2 not 1 as it should?
    I was going to do a forced toner sp2-207 but thought I better ask. Is my pump stuffed or is it the developer issue.
    The copies come out with extreme fading in the Black department on every copy like its out of toner?
    I have spare machines, should I replace the toner transport system? or toner supply unit?
    What do you think, your wisdom will be much appreciated.
    Regards
    Paul
  • Max
    • Oct 2011
    • 593
    Re: 2238c Black?
    sounds like you missed a connector somewhere on the k dev/drum area. As i remember you have to take off quite a bit to get to the back of the gears ass'y. Strip everything down and check every wire.
    • zflash7
      • Jun 2012
      • 39
      Re: 2238c Black?
      Why not Max, I'll try anything twice. Tks..
      • zflash7
        • Jun 2012
        • 39
        Re: 2238c Black?
        No pulled it apart and went through every wire again. still the same copies a fading black and three 15mm lines on back page with horizontal cross match color pattern all very light.
        I give up does anyone have any ideas? please...
        Regards
        Paul
          • 37728
          Re: 2238c Black?
          You may need to replace the black toner pump. It is a pain on this model. You could also have a clogged toner supply tube or a ruptured diaphragm on one of he vibrator pumps near the toner bottles.
          • zflash7
            • Jun 2012
            • 39
            Re: 2238c Black?
            Just about to put the machine in the shed. I have 3 x 281c Estudios. But little toner, whereas I have buckets of toner for the 2238c. Stuff this I need to do a print run today.. Ohh my back.. Toner pump hey? hum.. TNT might do a better job. Is that the one behind those freakin coggs I just replaced when replacing the motor...????? if so ..........one of the 281c is coming out of the shed..
            King regards....
            soon to be weight lifter Paul
              • 37728
              Re: 2238c Black?
              King regards....
              Whole bunch of things that have to come out of the front and top, including the laser unit, to get at the pump. In can be done without removing the laser unit, but it makes it a lot easier.
              • zflash7
                • Jun 2012
                • 39
                Re: 2238c Black?
                OK Thanks..
                now all I need is buckets of 281c toner..
                My decision is made.. you have been very helpful. Ebay.. ?? the answer...
                Regards
                Paul
                • sandmanmac
                  • 3985
                  Re: 2238c Black?
                  Have you tried another black dev unit? Sounds to me like it could just be a broken dev auger. So while the toner may be being fed from the pump, it's not loaded and.dispersed inside the dev unit. A good indicator is if toner is building up on the rear of the dev unit at the toner entrance.
                  • zflash7
                    • Jun 2012
                    • 39
                    Re: 2238c Black?
                    no build up. check the developer 1st and replaced.
                    OK so I have an estudio in my office now and I will post on that forum. as it makes a grinding noise when starting..
                    I'm over the ricoh's..
                    Thanks..
