After I replaced the drum drive motor and the gears, a few copies later........
The black toner will not fill up the development unit. First sc393-01 came up development error.
Then I did a reset and then sc386 gamma error, I did another reset of the black toner then Toner supply mechanism came up.
Also my process control self check sp3-975-001 comes up at 2 not 1 as it should?
I was going to do a forced toner sp2-207 but thought I better ask. Is my pump stuffed or is it the developer issue.
The copies come out with extreme fading in the Black department on every copy like its out of toner?
I have spare machines, should I replace the toner transport system? or toner supply unit?
What do you think, your wisdom will be much appreciated.
Regards
Paul
Regards
Paul
