Toshiba estudio 905 = Ricoh Pro907?
  • Albanytech
    • Feb 2015
    • 2
    The Ricoh dealer I work for is taking over service on a Toshiba estudio 905. I have been told it is the same machine as a Pro907 and it looks the same in pics I have seen... can anyone verify that for me? If it is a 907 does it use the same Ricoh toner and developer or does it require Toshiba supplies? Lastly is access to SP mode the same as a Ricoh? Thanks for any info.
    • 23010
    Re: Toshiba estudio 905 = Ricoh Pro907?
    Yes, Don't know, Yes, and Yes.
    The only one I'm not sure of the the toner RFID. =^..^=
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I know the 907 very well, it doesn't use a toner RFID setup. Don't know what hacks Toshi did to it but I'm assuming not too much...... This was a machine swap Ricoh did with Toshi to get the much maligned 3131 color box a few years back................
      Toshi got the better end of the deal!!!!!!!!!!
      Mystic Crystal Revelations
      • fuwei2422
        • Nov 2014
        • 49
        Toshiba estudio 905 = Ricoh mp900
        • Luther
          • May 2006
          • 682
          everything is the same except toner cartridge is different on the end, and the toshiba toner is much more expensive, like with most rebadged machines, the new high end toshibas are now sharps
          • bob marley
            • Jan 2012
            • 1339
            Thanks for the unexpected information
            Live for yourself and you will live in vain. Live for others, and you will live again
