Perfect Binder: A1 OR GB5000-5010
  • JDS
    • Apr 2011
    • 40
    Does anyone know if the Perfect Binder GB5000 or 5010 (Ricoh model) can be used alone - offline?
    Or does it have to be installed on a copier as in-line?
    Note - this is the same binder also called the Binder-A1 by Canon.
    Thank you.
    • 37513
    Re: Perfect Binder: A1 OR GB5000-5010
    From looking at the service manual, the paper enters the Perfect Binder one page at a time. The upstream equipment must send a signal when the last sheet has been fed in.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Ricoh doesn't offer the off line version of this unit.........
      Mystic Crystal Revelations
      • JDS
        • Apr 2011
        • 40
        Thank you Toner Bomb and Slimslob:
        Yes, it needs a copier to operate it then.
        Jeremy D
        • Celio Pinheiro
          • 7
          Those anyone can help with error SC751-40 on this GB5010?
          Tks
          • TonerMunkeh
            Professional Moron
            • 3865
            Hit it.
