Ricoh MP C300 Scan To E-Mail with GMX
  • dRONKEL
    • Jul 2025
    Hi Guys,
    iam trying to set up Scan to E-Mail on a MP C300 but it just does not work.
    The Firmware is up2date.
    i called ricoh, they told me that i need to import the Certificates -> Where do i get them?
    #[dcs_nas(126)]15/02/16 09:51:14 SMTPC: SSL Negotiation failed. ERR:
    That what the Protocol says, doesnt realy help me.
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh MP C300 Scan To E-Mail with GMX
    I am using GMX and it is very easy to use. Make sure to test the connection of smtp and your DNS.
    Nobody is perfect..
      • 37489
      If you model listed is correct, see the attached. If the model is actually MP C3000, it is too old to support SMTP over SSL.
      How do I setup SMTP over SSL on a Ricoh Family group device.pdf
      • techsass
        • Dec 2010
        • 248
        Another link for the certificate.
        How to configure SSL_TLS for Scan to Email.pdf
        Or you can try ASPMX.L.GOOGLE.COM using Port 25, but you'll probably have to change the setting on their account to "Don't always require SSL".
        • sandmanmac
          • 3981
          GMX does not require encryption.
          All that needs to be entered is:
          Administrator email address: whatever you like
          Smtp server: smtp.gmx.us
          Port #: 587
          SMTP Authenticatication: On
          Smtp Auth email: xxx@gmx.us
          Smtp Auth user name: xxx@gmx.us
          Smtp Auth password: xxx
          ...And of course the proper DNS, GW, and SM
          • dRONKEL
            Thanks for the quick answers.
            Its definitely a MP C300.
            i've tried these settings, they dont work for me.
            I also have the Service Information PDF from Ricoh, doesnt realy help...
            Since 2014, GMX and a couple more E-Mail Provider require encription. (E-Mail made in Germany)
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Make sure Network Support and Web Support firmwares are both up to date.
              Also, make sure that the DNS is entered and the primary DNS is either a local DNS or the ISPs. The secondary and tertiary DNSs can be Google's 8.8.8.8 and 8.8.4.4, which sometimes help. If you can't connect to mail.gmx.com, then try the IP 212.227.17.184 although this may change at a later date, it is worth trying to see if it is a DNS issue.
              • dRONKEL
                The Connection MFP -> GMX works fine.
                MFP says connection to mail.gmx.net(or IP) is successfull.
                  • 37489
                  Connection test in User Tools - System Settings - File Transfer does not mean that the MFP is able to authenticate. Many email services are starting to require TLS/StartTLS authentication which most MFPs are not able to use. Also, some ISP's block all normal SMTP ports to any server except their own. One option that still works is to use a GoDaddy email account for SMTP GoDaddy's email server, secureserver,com, can use port 80, with or without SSL. ISP cannot block port 80 as it is the port used for internet.
