Proplem with ricoh aficio mp c2500
    • 37533
    #16
    Re: Proplem with ricoh aficio mp c2500
    Originally posted by aliomr
    why does it copy good without that plastic bar , its just doesn't make any sense
    Because the plastic hold down bar holds the glass down slightly as compared to when it is removed.
    • Polarbear
      • Feb 2012
      • 1070
      #17
      by a ping you mean that the glass is touching the exposure lamp so it makes this sound , right ? , also why does it copy good without that plastic bar , its just doesn't make any sense , i'll give it a slight push down with my hands to see if that works , thank you very much , your a great man , if you need anyhelp with softwares or something give me a call , i'd love to help you
      What i mean is if the glass is not sitting square on the scanner frame, the glass (if tapped_ will make a clear "ping" sound, as it will resonate because it is not supported on all sides by the scanner.
      If it is sitting square on the scanner, the rubber supports will make the "ping" sound dull.
      The glass never touches the scanner lamp, as there is a clearance between the glass and the scanner lamp so that it can pass under the glass as it scans the document on the glass. If it is touching, something is seriously wrong.
      Press the GREEN button!!
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        #18
        Originally posted by Polarbear
        I wish Ricoh would design their machines with a post left front under the scanner!
        This will solve so many optical issues!
        Most of the range do come with a plastic bar that supports the scanner during transit, however this is usually removed as it can cause problems for larger paper sizes. For the newest rnage it is placed inside the front door to cover the factory defaults sheet.
        • aliomr
          • Feb 2015
          • 6
          #19
          The exposure lamp is curved from the middle, i removed the glass and left the plastic bar, then i turned off the machine, when the scanner started to move to home position, it kicked the plastic bar off., i looked at the exposure lamp to find it curved up from the middle, couldn't find a way to straighten it, any ideas
          Thanks again
          • Polarbear
            • Feb 2012
            • 1070
            #20
            Thanks again
            Could you possibly post photos of this curved scanner lamp?
            • Mark Bbb
              • Jun 2012
              • 1662
              #21
              When Ricoh machines come out of the box, they have a bracket between the receiving tray and the scanner. That is to protect the scanner for bending. Here in Belgium (yes, Belgium still exists!), Ricoh remove this so important bracket. It is not possible to order it afterwards, so now all our machines have skewed copys, that is a big problem. I have had 3 (!) good working mp2000 "per total" by simply adjust the scanner in good position. The machines broke after this adjustment and now give al kind of codes now... Anyone a solution, i would be gratefull.
              • Polarbear
                • Feb 2012
                • 1070
                #22
                Can you post some of the codes?
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  Polarbear,
                  It was about half year ago, they gave all kind of SC codes... What i mean with "a solution" it is for the missing bracket which is not available here in Belgium... Thank you for replying anyway!
