Hello,
i have a ricoh aficio mp c2500 color copier and it driving me crazy :@
when i put a paper on the glass and give an order to copy , the machine start copying fine
but the copied paper has completly black part all the way down but if i put my fingers under the touch panel and give a slight push up it works fine
and if i press down the black blank part gets bigger , i dont know what the hell is this , the scanner works fine and no proplem with it because as i said when i left up it works fine and the copied paper is good , but i dont know what to do , please help
i can post pictures to make it easy for you to help me , but please give me some advice , i know its something easy to fix but i cant figure it out
i can also explain the proplem in a video to make it easier to understand the proplem , please help
thanks in advance
thanks in advance
