PUNCH UNIT B702
  • garyk
    • Jan 2007
    • 37
    PUNCH UNIT B702
    what are the dip switches on punch unit board(pcb3) for? and what are correct positions?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: PUNCH UNIT B702
    DIP Switch settings:
    2-Hole Punch (Japan) 1: OFF 2: ON
    4-Hole Punch (Overseas) 1: ON 2: ON
    • garyk
      • Jan 2007
      • 37
      Re: PUNCH UNIT B702
      what is correct settings for (usa)
        • 37637
        Re: PUNCH UNIT B702
        You have not specified the finisher and MFP models that the punch unit is being used with. DIP switch settings are usually in the MFP or finisher service manual.
        • Cipher
          • May 2006
          • 1309
          Re: PUNCH UNIT B702
          The US version of the hole punch unit is probably different.
          Letter size would commonly be hole punched with 2 or 3 holes, but probably not 4 holes as Letter is shorter than A4.
          • garyk
            • Jan 2007
            • 37
            Re: PUNCH UNIT B702
            ricoh aficio mpc7500 with sr4010 finisher i have checked service manuals and could not find dip switch info
            • garyk
              • Jan 2007
              • 37
              Re: PUNCH UNIT B702
              what manual are you getting dip switch settings? i looked in service manuals for: af mpc7500,sr4010, hole punch 3260
              • Cipher
                • May 2006
                • 1309
                Re: PUNCH UNIT B702
                From an alternative support resource, not the service manuals.
