Ricoh Aficio MP7000, Toner Supply Problem
  • mterrero
    • Sep 2011
    • 60
    [CQ] Ricoh Aficio MP7000, Toner Supply Problem
    ( toner is not supply on the developer )
    I make a force toner supply manually opening the developer unit and the copies became dark ( Perfect copies ), for son reason the machine is no supplying toner automatically
    Can someone Help me
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Ricoh Aficio MP7000, Toner Supply Problem
    Most of the toner supply problems we've had with most of the B&W range have nearly always been the toner bottle stop cap being stuck or left over from the previous bottle.
    • TonerMunkeh
      Professional Moron
      • 3865
      I've had the toner add clutch fail on the dev motor pack. It's not replaceable on it's own, it must be replaced as an assembly. If you run the clutch in output mode, you should get a good, solid click out of it. If not, it's had it.
      Hit it.
      • mterrero
        • Sep 2011
        • 60
        The toner motor assy was change from a working machine, I havent change the IO board ( were the cluch is connected ), thats the next test
        • mterrero
          • Sep 2011
          • 60
          Hello Ruben, this happen on mid volumen ( 22 to 45 PPM ) but on 55-75ppm the system is diferent, the toner hopper on the developer unit is full of toner, but the toner feed motor clucth must be activated in order the toner fall on the developer
            • 37628
            You can also have the holes in the toner metering plate on the bottom of the toner hopper can become clogged, especially if you are using after market toner.
            • mterrero
              • Sep 2011
              • 60
              Developer unit was changed complete and installed a new developer..
              • Iowatech
                Not a service manager
                • 3930
                I don't know if this applies anymore, but higher speed Ricoh machines were built to be used in higher print volume applications. The upshot of this is that if you don't use the machine enough, the toner feed motor doesn't run long enough, and over time the toner becomes depleted causing low density prints.
                If this could possibly be the case, you can either run higher print count jobs on the machine or reduce the toner feed time value in service mode.
                Or it could just be non-OEM toner. That's somewhat improbable though.
                Sorry if this is a waste of time.
                • Max
                  • Oct 2011
                  • 569
                  When you adding toner via SP mode connect the meter to the motor terminals and see if there is any power going to the motor and trace the wires all the way to the IOB board and test the pins on the connector. Also check the toner sensor on the hopper. I know you said you changed it but if it doesn't make the whistling sound when you connect it it could be the wire leading to it.
                  • redneckstylin
                    • Sep 2011
                    • 173
                    double check the dev unit there is a filter on top that you need to swap off old unit if not it will dust the laser glass and light prints...
                    • chand
                      • Oct 2007
                      • 12
                      Check developer unit.
                      And initialize td sensor in service mode
                      • mterrero
                        • Sep 2011
                        • 60
                        problem Solved, Finally, the problem was a Generic Transfer Belt, changed with a new OEM and Problem Solved..............Thanks for yoyr help
