problem with mpw2200
  • en.
    • Jul 2014
    • 124
    hi all
    the problem with ricoh mpw2200 is give me the massege (front cover is open )
    i checked the right switch door in input check and its ok its
    and i checked front pre sensor and its also ok and work properly
    but when i checked the left switch door in input check the last digit (ooooooo1) the digit (1) never change to (0) like (right switch or another sensor )
    and i checked all connector \ its ok
    any one can help me please
    best regards
  • en.
    • Jul 2014
    • 124
    Re: problem with mpw2200
    HELLOW
    ANY BODY HERE?
      • 37059
      If this information does not tell you where the problem is, you are not a tech. Either that or you need to find a new line of work. Hire a qualified technician.
      • en.
        • Jul 2014
        • 124
        Thank sir for your advice to find anew line work >>>
        i replace all switch door and checked the connection and wiring >>all this is ok and work properly
        but the message is still ( front door open )
        any one can guide me how to reset or resolve this problem
        best regards
        • Polarbear
          • Feb 2012
          • 1070
          There is a problem with your model number: It is either an mpCw2200 or MPW2400 as I cannot find a MPW2200 anywhere.Please correct this then we can attempt to help you.
          Press the GREEN button!!
          • Moza
            • 232
            See my response in the thread below
            • vga_man
              • 78
              i've the same problem later but i checked the door sensor and cleaned it
              • rexrotary
                • Feb 2015
                • 19
                hi all,
                I have face same problem still no soluation. I have worte to ricoh As per they advice i have change the print head colour and black, MCU BOARD ,HRD BOARD, POWER SUPPLY BOARD, still the same......
                best regards[/QUOTE]
                • rexrotary
                  • Feb 2015
                  • 19
                  Hi all,
                  I have installed MPCW2200 machine more then 20. most of the machine we are facing problem paper jam. any body facing same problem please let me know. I have updated the latest faimware and some machine i have replace ENCORDE STRIPPER temporary machine will work.
                  • Ricoh-ono
                    • 339
                    Check the ribbon cables near the Print Head. Tech Service Bulletin 8 covers this.
                    Most often this occurs because there was a loss of the 5v trigger which comes from the print heads through to the
                    MCU Board. This 5v line is used by the MCU to turn on the 37 volts coming from the Power Supply and going
                    through the Front Cover Door Switches.
                    Do what you can, with what you have, where you are. ~Theodore Roosevelt
                    • flo
                      Engineer
                      • Mar 2009
                      • 44
                      hello You have a problem with the Engine Board!
                      After changing Printheads or some other Parts in this Area you have to disconnect Flat Cables. This flat have connection lines they stay very near to each other, and by reconnecting this its a very dangerous procedure to get them to the right place. often you get there a schortcut here and after reinitializing the machine schow you open Door switch. I see this by more than 10 machines used ore near new. try this i think its the Problem for this MPC W2200
                      • Gary Bowen
                        Bowdog
                        • Mar 2008
                        • 250
                        This is the Technical Bulletin Ricoh-ono was referring to. I am surprised that Ricoh Tech Support did not point this bulletin out to those who are supported by Ricoh.
                        • rexrotary
                          • Feb 2015
                          • 19
                          Good morning,
                          I have face problem with mpcw2200 while printing or getting copies appearing black lines. any body can help me............Thanks
                          • rexrotary
                            • Feb 2015
                            • 19
                            hi,
                            how to set up scan to google map+ office 365 same time with mpcw2200. Please anybody can help me
                            • rexrotary
                              • Feb 2015
                              • 19
                              sc-282-12
                              Good morning,
                              I have facing problem with mpcw2200 with error code SC282-12. This error related to air leaking even if get this error we can not reset also. any body got same issue please inform
                              thanks
