parallel connection to ricoh aficio 4502
  • latebloomer37
    hi, im a noobie here but appreciate if you can assist me with this issue.
    My boss wants me to connect using an xconnect -II LT box to the parallel port of our ricoh 4502 for testing purposes. Does any of you guys have any experience/know in doing this? If you have any idea can you please point me to a link or website the would guide me thru the installation.
    thanks so much.
  • Serviser
    • Jun 2007
    • 16
    can you explane litlle detailed?
    using an xconnect -II LT box to the parallel port???
    • Jomama46
      • 2900
      Yeah, what is a "xconnect -II LT box"
      sigpic
      A+; Network +; PDI+
      • FRIDGEMAGNET
        • Aug 2007
        • 377
        xconnect -II LT box
        This is a print server that connects to the parallel port.
        You will need to check if you have the printer/scanner option installed.
        Press the user tools key and there should be a printer option on the display and print a config page.
        If you have the option go to the Ricoh website and get a driver - all basic stuff - shouldn't be a problem.
          • 23009
          I'm just guessing here, but this "xconnect box" sounds like an external print server, and further I'm guessing that you're trying to network print thru the print server to the parallel port of the MFP.
          The first question I have is this really a parallel print port, or is it just a way to load firmware to the MFP? =^..^=
          • latebloomer37
            Hi Guys, Thanks so much for the replies.
            your right blackcat4866 about " trying to network print thru the print server to the parallel port of the MFP" . The reason why the boss wants to try out the xconnect server connection is our SAP guys are thinking the "Ricoh printer's network implentation is not compatible with our SAP printing environment".
            Printer would usally jam when printing SAP jobs and would only allow one active connection.
            Will check on FRIDGEMAGNET suggestion and update you guys. Again thanks a lot.
            • iMind
              Vacuum Cleaning Expert
              • Mar 2008
              • 1116
              Hi,
              I´ve got a 10505 with an AXIS print server "recomended by ricoh" with HPLJ4 driver, working with SAP R3, prints fine.
              All our machines work with SAP, SAP R3, R3 enterprise, mySAP ERP.
              from Aficio 350 up to MP8000 and colour. the worst part is setup, but thats for the SAP administrators
              SAP device types to use: PCL-based ZA0x, ver 005+
              Device / Model name: 9005 / 9008 / 9002
              Compatibilities/Emulation: HP LaserJet 4 PCL 5e
              Firmware (PCL): Note: It is recommended to always use the latest firmware.
              Speed: 90 ppm (A4/LTR simplex LEF) Printer queue name lp.
