MPC305 jamming from option tray
  • GeorgeBest
    • Jul 2009
    • 526
    Visiting a customer tomorrow complaining about lots of jams from tray2 (optionel)
    not much experience on this model.
    anyone tips of a clue here . . .
    thanks in advance
  • SargeNZ
    • May 2012
    • 263
    Re: MPC305 jamming from option tray
    The SMC report is your friend (5-990-4)
    I have seen lots of cases of the paper end fence being missing or away from the paper.
    • Counsel
      • Aug 2011
      • 529
      I had one the other day with the option tray, one nice thing is they put a back cover on the option tray so you dont have to lift off the machine to see the clutch and motor, the one did wouldnt feed at all (less then 3k total on machine), i took out the clutch and poor some alcohol inside the gear slapped it around in my hands a bit, then put it back in and reseated all the motor and clutch connectons haven't heard back since that was 3 weeks ago.
      • knarfdnul
        • Apr 2011
        • 27
        I had 2 new tray 2 units with no feed problem - the metal plate was not pushing enough on the rollers - bent it at Little and then it was ok.
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Also an option is to update the FW of the PB1050, there exist the version "C" for tray 2 & 3. This helps against c 502/503 & the lift performance is better.
          Greetings...
          • Zaxxon
            • 608
            I had broken paper end sensor causing jam on these little fuzzers.
            Please start you post with brand, model, problem.
