savin C3535-Ricoh C3500 power supply problems
  • odie
    • Sep 2010
    • 11
    [Dead] savin C3535-Ricoh C3500 power supply problems
    Working on a Savin C3535.
    This one received damage to the rear panel. Found that the power supply
    (Ricoh AZ240109) was damaged, cracked board. I repaired board soldering wire
    leads over the crack in the board. and reinstalled the board.
    My question, the unit still does not power up. Fuses are all ok. Can hear a relay type click from board
    when power switch is turned on. I don't have a service manual for this copier. Is there a physical reset I have to
    preform after the power supply board is installed?
    The board may still be damaged and is causing the problem, if so does anyone have a used AZ240109 board to sell
  • sandmanmac
    • 3979
    Re: savin C3535-Ricoh C3500 power supply problems
    If the board (S) were 'ok', then quite simply the machine would power up
    • ZOOTECH
      Senior member of CRS
      • 3375
      Quite possibly the circuit board is multi-layered, and you missed a trace or two.
      • TonerMunkeh
        Professional Moron
        • 3865
        Recycled Parts have them, they're about $120. Just Google the part number.
        Hit it.
        • odie
          • Sep 2010
          • 11
          Got it working.
          Replaced power supply board with new one.
          works good now
