Ricoh MPC305
  • MunsterTech
    • Sep 2014
    • 381
    [Error Code] Ricoh MPC305
    Hi,
    First time seeing the Ricoh MPC305, it has an error code of SC202, I dont have access as yet to the parts or service manual. I googled the error code and it seems to be related to the polygon motor. Does anyone have the part number for the polygon motor, for 230/240v? Tks v much
  • copier tech
    • 8138
    Re: Ricoh MPC305
    The model only has 2 lasers, both the same, you can swap them around to fault find, might just be a loose connection
