1045 customer says
  • hodgiepodgie
    • 284
    1045 customer says
    customer said copy enlarged and everything black is white and white is black could not duplicate problem.had com error code and hdd error code. HDD OR BICU?
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    Did they do an enlarge/negative image selection? Error codes may be random codes. Perform a bad-sector check and maybe reformat the HDD.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • ZeusGT
      • 271
      I agree, check to make sure that they didn't do a reverse negative copy.. Other than that it would be the scanner/ccd board if there was to be a board that was in question...
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • Jimbo1
        • Mar 2008
        • 845
        I wouldn't go spending money on boards till you find out what those codes
        are. Boards are rarely the answer and it does sound like someone was operating with their feet.
        Format the hard drive. Maybe reload firmware but buy a board as last resort.
        Always!
        "Some days you get the bear, some days the bear gets you."
        Cdr. William Riker
        • Jomama46
          • 2900
          It can easily be a HD problem but that is also easliy checked, just disconnect. The machine will operate but with less functionality.
          sigpic
          A+; Network +; PDI+
          • hodgiepodgie
            • 284
            all great ideas .performed hd format etc.chkd codes,will see how it goes from here thnks guys.
            • b003ace
              • Jun 2008
              • 78
              HDD standard on 1045
              The machine will pitch a fit about normal operation without the hard drive, but it will run in service mode without it. The hard drive was standard, so they use it for almost all multiple set copies, especially if sort or rotate sort is used.
              • fausto1981
                IT Technician
                • Dec 2007
                • 145
                I have nothing else to say, you guys covered everything...
