ricoh pro 1106ex hot roller strippers jam
  • aaahmmm
    • Aug 2009
    • 103
    Dear all , I have jam on the fuser on ricoh pro 1106ex the jam exactly as in attached pic ,it is on the hot roller strippers I replace them but still the same jam .
    Please advice
    • 23008
    Re: ricoh pro 1106ex hot roller strippers jam
    Which attached picture? =^..^=
    • aaahmmm
      • Aug 2009
      • 103
      sorry , here is the picture
        • 23008
        I can see a few things in your picture:
        1) Your images do not seem to have excessively heavy fill at the leading edge. Is duplex worse than simplex?
        2) It seems to catching the center claw, and I see a few rotational lines on the heat roller. Is the fuser roller coating worn through? Claw(s) blunted? Has the web dried out?
        There are things I won't be able to see in your picture:
        1) How much leading edge and trailing edge void?
        2) Are you experiencing excessive paper curl? If yes, does your enduser consistently load the paper a certain way? Do you have compensations to counter paper curl?
        What jam codes?
        That should get you started. =^..^=
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          does your stripper pawls are new? AE04 4067?
          fix the customer first then fix the machine... its simple and makes life more easy.
          • Coptech
            worker drone
            • 460
            When you rebuild the fuser, do it with the pressure release levers flipped down for no pressure. That way the fuser gets "tightened down" when square. Then apply pressure before re-installing fuser.
            • aaahmmm
              • Aug 2009
              • 103
              I have another machine in the same site running fine , I did swap and try for the stripper unit , the problem move to the other machine so the problem in the stripper assembly , I install new stripper pawls for the problem stripper assembly but still same jam ( jam code 21) I checked the assembly it looks fine but still have same jam .pleases help
              • subaro
                • Oct 2010
                • 1274
                check the springs or however those finger are kept down. do they have individual spirngs for each finger ? lift each finger with small knife of pointed object and check the spring tension on each. swap the center spring for one on the end or replace the springs. maybe that spring in the center is weak and not sitting firm on the roller
                  • 37491
                  I have to agree with subaro. It looks to me like the center pawl might not be contacting the hot roller. Either the spring is bad or missing or the stripper frame is warped.
                  • Mocafer
                    • Mar 2015
                    • 23
                    Many times I have seen this problem and solved by cleaning the axes of the small round pieces that come together to nails, these are filled with toner and do not rotate. in the photo you are using but seem clean.
                    • impetus73
                      • Mar 2012
                      • 75
                      If the jam happens at the same stripper every time, remove the stripper permanently. You only need 2-3 strippers in a 5 stripper set, for it to work :-D
                      • Codex
                        • May 2008
                        • 704
                        First one question, the stripper are original??.I had exact the same problem with non original strippers, changed with originals and no more Jam 21........
                        Then clean the black guide on every visit.
                        Memento Audere Semper
                        • mdfurqan2012
                          • 194
                          Dear
                          P as per jam 21 is also occurs due to the dirty paper guide. Clean both guides by alcohol can remove your problem.
