ricoh 5000&4000
  • yasir
    • Mar 2007
    • 19
    [CQ] ricoh 5000&4000
    we have this problem in Ricoh 5000 it runs copy quality problem faint or background
    change the developer fixed ,but returns again any setup routine
  • Gift
    • Mar 2011
    • 2459
    Re: ricoh 5000&4000
    Are you using OEM toner/drum? How's the current yield-status of the PM parts? Did you clean the mag roller properly?
    • Zaxxon
      • 608
      Re: ricoh 5000&4000
      1. PCDU ( p.183)
      2. Open the PCDU. ( p.183)
      3. Development roller ( p.191)
      4. Joint bracket [A] ( x 2)
      5. Development unit [B]13. Place a piece of paper [G] over the toner entrance hole. This prevents used toner falling from the drum
      unit into the development unit during the TD sensor initial setting and interfering with the Vref setting
      (toner density reference voltage)
      14. Secure the drum unit [H] to the development unit, to close the PCDU ( x 2).
      15. Install the PCDU in the machine and close the front and right doors.
      16. Turn on the main power switch, and wait for the machine to warm up.
      17. Do SP2801 to initialize the TD sensor and enter the developer lot number.
      18. After performing the TD sensor initial setting, remove the sheet of paper from the PCDU.
      Please start you post with brand, model, problem.
        • 37556
        Re: ricoh 5000&4000
        Is there a reason why you posted this in both the Ricoh Copier forum and the printer forum?
        • Bantams
          • Jun 2012
          • 603
          Re: ricoh 5000&4000
          Sounds like a sticking dev drive clutch
          • PA3040
            • Jun 2014
            • 171
            Re: ricoh 5000&4000
            In our case we cleaned the development roller every 25,000 copies, That the only solution we have but bad practice
            • Codex
              • May 2008
              • 704
              Re: ricoh 5000&4000
              Very bad machines.... I experienced very strange problems.....if you open and close the side door.... It can happens that the machine starts with doing light copies, without any reason... The copy before was perfect.... One time i was so angry because i only checked the fuser and the machine makes light copies after that...... So.... I kicked the side door with the foot...... And the machine starts to work... No service call since 3 months.....
              Memento Audere Semper
              • Codex
                • May 2008
                • 704
                Re: ricoh 5000&4000
                ..... But ZAxxon is right.... Follow this procedure, i experienced also to change drum, developer before the target yield..... ( suggested by ricoh hotline)...... And make sure that the trasfer belt contacts are clean, to prevent light copies
                • mazzi
                  • Jun 2010
                  • 10
                  Re: ricoh 5000&4000
                  This machines are real pain in the ass (this includes sp8200 as well). We had continuous problems with this until we modified them to earlier moddels, becouse the mag roller was dark black and developer was like burnt on the mag roller it self. It took you 10min to get it clean but still after 20-30k all over again + most of the time drum change to get a decent copy!
                  To get this problem fixed permanently you need to change toner motor (i think the code is AX05 0239), toner for the Ricoh 2035/3035 machines, and put in dev type 26 and they are now working now like a charm!
                  BR
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Re: ricoh 5000&4000
                    We use the sp8200DN printer kits for these machines.
                    The A kit is the complete PCDU and the B kit is the fuser and transfer assy.
                    The only modification for the pcdu is swapping over the front cover of the drum unit.
                    NO modification required for the fuser or transfer assy....straight swap.
                    • JACK MUNDA
                      • 9
                      Re: ricoh 5000&4000
                      How many copies has the transfer belt done if over 350k try replacing .
