Ricoh Pro C901s Graphic Art Edition - Conflicting GSM info
  • 316roth
    We have seen conflicting information for this machines acceptable paper media weight. I have seen brochures that say it will accept 350 gsm but have heard people say that it will not take that. Anyone have a way to be sure? We know that the ProC 901 GA Plus does 350 gsm as I have talked to someone who also runs that machine to confirm it matches the brochure I saw list it as its max gsm.
    We were told that the Pro C901S Graphic Art Edition does the 350 gsm because of the graphics art edition portion.
    Any info appreciated or links to help -- thanks!
  • Gamut
    • 216
    Re: Ricoh Pro C901s Graphic Art Edition - Conflicting GSM info
    You need to have LCT fitted for straight(ish) feed path you can't auto duplex for obvious reasons and it should be Ricoh approved stock.(in media library)
    I have customers trying all sorts and tell them if not approved don't call in for jams.(they don't listen and try to blag it used to work ok!!)
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      The Pro c901 GA+ only supports 301 to 350 gsm From the LCIT and is also spec'ed to duplex 350 gsm. AS Gamut said you need to use media from the paper library for best results..............sorry the formatting of the copy/paste sucks...
      Product Support Guide
      M077+/ D095+
      Page 34 of 86
      8/12/2013
      Ver.1.4.2
      Subject to change without notice
      Specifications / Documentation / GW Controller:
      Hardware Specification (Common to Printer and Copier version)
      Items
      Specification
      Remarks
      Configuration
      Console
      Copy Process
      4-drum dry electrostatic transfer system with
      internal transfer belt
      Fusing
      Oil-less Belt-fusing method
      Toner Type
      New PxP toner
      (Polymerized oil-less full color toner)
      Engine Speed
      FC
      90 ppm
      A4/LT(LEF)
      BK
      90 ppm
      Warm-up Time
      Less than 420 sec.
      23C ̊ @ rated voltage
      Limitless Paper Supply
      Supported
      Paper Size
      Please refer to “Paper size matrix”.
      Maximum Printable Area
      320 mm x 480 mm / 12.6” x 18.9”
      Hardware Specification: (Common to Printer and Copier version)
      Items
      Specification
      Remarks
      Paper Weight
      1
      s
      t
      tray
      60.0 – 220.0g/m2
      2
      n
      d
      tray
      60.0 – 220.0g/m2
      A4/
      LT LCT
      3
      r
      d
      tray
      60.0 – 216.0g/m2
      4
      th
      tray
      60.0 – 216.0g/m2
      5
      th
      tray
      60.0 – 163.0g/m2
      A3/
      DLT LCT
      3
      r
      d
      tray
      60.0 – 350.0g/m2
      Support for 301 to 350g/m2
      C901GA+ only
      4
      th
      tray
      60.0 – 350.0g/m2
      C901GA+ only
      Bypass Tray
      60.0 – 216.0g/m2
      Simplex
      60.0 – 350.0g/m2
      C901GA+ only
      Duplex
      60.0 – 350.0g/m2
      C901GA+ only
      Paper Weight Setting
      Paper Weight 1
      60.0 – 63.0g/m2
      Paper Weight 2
      63.1 – 80.0g/m2
      Paper Weight 3
      80.1 – 105.0g/m2
      Paper Weight 4
      105.1 – 163.0g/m2
      Paper Weight 5
      163.1 – 220.0g/m2
      Paper Weight 6
      220.1 – 256.0g/m2
      Paper Weight 7
      256.0 – 350.0g/m2 GA+ Only
      256.0 – 300.0g/m2 Non GA
      C901GA+ only
      Support for 256 to 300g/m2
      C901GA
      Mystic Crystal Revelations
      • 316roth
        Will that model run Media up to 350 gsm?
        thanks
