ProC901 Jam 036 300g stock
  • mrwho
    Major Asshole!
    • 4299
    [Jamming] ProC901 Jam 036 300g stock
    Good morning, people.
    I'm having these odd "jams" on the C901. And I say "jams" in between quotation marks because the paper doesn't jam, but it stops for a moment before heading for the purge bucket.
    So the machine can make about 30 sheets of paper in a row before jamming. But when it jams, I can no longer make another sheet, because it will keep on jamming.
    The machine will have 4 sheets jammed when I open it up, in this order:
    1st sheet: Purge bucket with both sides printed
    2nd sheet: On the right side of the duplexing unit
    3rd sheet: Reverse unit
    4th sheet: Just between the paper feed tray's rollers
    With the door open, I can observe the 1st sheet stopping at the registration gate for a longer time than usual before heading to the purge bucket.
    I've tried swapping sensors around the registration unit, adjusting the paper feed's paper height and even tried a completely different registration unit from a different machine.
    Finally, one last bit of a perhaps important information: the paper the customer is using is unusual in that it is coated on one side and plain on the other. I don't really know if it can explain this problem, but the fact that the machine can make a handfull of copies before starting to jam leads me to believe that it should be able to (and the fact that the customer already used this paper in the past without any problem, and keeps using it on another different brand machine).
    Thanks!
    Mascan42
    Ibid
  • Gamut
    • Jul 2008
    • 216
    Re: ProC901 Jam 036 300g stock
    Check jam code on SMC, probably double sheet feed being activated by paper type, you can try turning dsf sensor off.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      from which tray? and is that tray set up with the correct paper type/weight parameters? or bettor yet is the media type in the paper catalog and selected for that tray........
      Mystic Crystal Revelations
      • mrwho
        Major Asshole!
        • 4299
        Thank you both for your replies.
        I should've mentioned that one of the first things I did was to disable auto image shift and double feed detection.
        As for the paper type, according to the customer the paper is in the paper catalog (Olliwhite), but I tried both the paper catalog and defining the paper manually, as well as altering the machine SPs to slow down the process, with no results.
        Mascan42
        Ibid
        • Gamut
          • Jul 2008
          • 216
          I really need to get some reading glasses.......
          • anothertech
            • 1771
            Yep, check the jam code, it's the only way your going to pinpoint it. Sooooo...that said, what is the jam code?
            • Gamut
              • Jul 2008
              • 216
              Your going to the same opticians as me......
              It's in the title, Jam 036
