Ricoh 1022 Cassette wheel only shows metric?
  • Mopar Freak
    • 55
    Ok, we have swapped some boards around, but the cassette wheels will only diplay A and B sizes. I can't seem to find anything in user tools or system settings to return it to inches. Two different SBCU boards were tried with the same result. Any ideas? Am I just missing something? Thanks ahead of time.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Hi Try this
    mm/inch Selection
    Selects whether mm or inches are used in the display.
    Note: After selecting the number, you must turn the main power switch off and on.
    Europe/Asia model: [0 = mm / 1 = inch]
    American model: [0 = mm / 1 = inch]
    • Mopar Freak
      • 55
      SP mode 5024 was set to 1. after restart same thing. display shows B5 for 81/2 x 11 portrait.
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        I would recommend flashing the firmware. I've had some strange things happen when swapping boards between machines that don't have the identical firmware versions and accessories.
        • Jomama46
          • 2900
          change SP5131 to 1
          sigpic
          A+; Network +; PDI+
          • iMind
            • Mar 2008
            • 1116
            Originally posted by Jomama46
            change SP5131 to 1
            • DRichard
              • May 2008
              • 482
              PWB Switches?
              I seem to remember getting new boards from Ricoh that on a couple of occasions, had the mini switches (those tiny banks of bit-switches) set for use in Europe. This info was not in the literature and the only way we confirmed the correct settings was to compare the new board with one from a functional machine.
              "Enjoy every sandwich."
              -- Warren Zevon
              • Mopar Freak
                • 55
                The Service Mangler strikes again! The 5131 was at 0. What I don't get is why the 0? I believe all the boards/copiers that were swapped worked correctly before being installed? I guess something caused one to go back to default?
                • iMind
                  • Mar 2008
                  • 1116
                  Thanks for the feedback
                  • Jomama46
                    • 2900
                    Glad you got it going.
                    Did someone clear the memory? This would reset that bit to 0.
                    sigpic
                    A+; Network +; PDI+
                    • Lagonda
                      • Aug 2008
                      • 1649
                      Of course you could join the rest of the world and go metric!
                      Life would be so much easier if Microsoft was a european company and wrote all its software with metric as the default setting!
