MP C5502
  • CrapAimer
    • 296
    MP C5502
    Hi All Small problem with a MP C5502 with an SC 899 any ideas much appreciated
    George
  • Zeldaman
    • Mar 2011
    • 946
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Re: MP C5502
      As Zeldeman says update ALL firmware (including JAVA). The last Firmware History update for this machine was March 12/2015. If the customer is not using JAVA disable it. There is lots on this forum for SC899 codes and Ricoh's.
      • CrapAimer
        • 296
        Re: MP C5502
        Updated the font firmware etc fault cured many thanks for your help
        George
        • kyoceran
          • 100
          Re: MP C5502
          found customer was trying to print an internet generated print, cleared the item from the print queue machine worked ok , good luck
          • copier tech
            • 8142
            Re: MP C5502
            Can I ask how does one disable Java? Is java only needed for 3rd party software like Equitrack etc?
              • 37474
              Re: MP C5502
              That is fine until someone tries to print a similar web page. If the firmware has not been updated, disconnect the network cable, update the firmware, reboot the MFP, reconnect the network cable. Do not worry about deleting the print job, it will print without error when cable is reconnected. I have had to update 3 okder color MFP in the last month. The offending font characters are on more and more web pages, including pages that many customers must to be able to print from.
