Mp6001 type controller is not the same with 8001?
+ More Options
Posts
  • zuojin168
    • Sep 2012
    • 83
    Why will appear in 995-995?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Mp6001 type controller is not the same with 8001?
    The controllers are not the same. SC995, is a controller mismatch error.
    • zuojin168
      • Sep 2012
      • 83
      That there's no way to put the controller fitted with 9001 above 6001?
      • zuojin168
        • Sep 2012
        • 83
        My 8001 print controller is broken.
        Should be the same controller.Why don't you like?
          • 37253
          No they are not. A number of boards in this model series vary according to the model speed. The power supply unit, BCU and CNB are different for the 9001. For the DRB the 6001 and 7501 are the same and the 8001 and 9001 are the same.
          The control board is the same for the 6001 and 7501. The 8001 and 9001 each have separate part numbers:
          D062 5607 PCB: D062: Service: DOM/EXP: Ass'y
          D063 5507 PCB: D063: Service: DOM/EXP: Ass'y
          D065 5505 PCB: D065: Service: Ass'y
          D066 5506 PCB: D066: Service: Ass'y
          I see that in the time it took for me to look up and post the above, 3 others also replied.
          • zuojin168
            • Sep 2012
            • 83
            You're should be 6001 and 7001 are the same.Rather than MPC7501
            Yes, because I have installed over 6001 8001 BCU, DIP switch is not the same.
            But I no control panel.
            Because I ricoh order is very expensive in China.And the time need a month.
            The factory pattern can be installed?
            • anothertech
              • 1759
              You have already been told IT WILL NOT WORK! What else do you need to know. Look in the parts manual and order the correct part.
              • zuojin168
                • Sep 2012
                • 83
                Originally posted by anothertech
                you have already been told it will not work! What else do you need to know. Look in the parts manual and order the correct part.
                ๅ› ไธบๆˆ‘ๆฒกๆœ‰ๅคšไฝ™็š„ๆŽงๅˆถๅ™จใ€‚
                ่€Œๆˆ‘็š„8001็š„bcuๅฏไปฅ่ฃ…ๅˆฐ6001ไธŠ้ขใ€‚
                ๆˆ‘ๅชๆ˜ฏ้œ€่ฆๆ”นๅ˜ไป–็š„dipๅผ€ๅ…ณใ€‚
                ๆˆ‘ๆฒกๆœ‰ไป–็š„้›ถไปถๆ‰‹ๅ†Œๅ’Œ่ฎขๅ•็ผ–ๅทใ€‚
                ๆˆ‘ๆ˜ฏๅฑžไบŽๆ—งๅคๅฐๆœบ็ปดไฟฎใ€‚
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  Because I do not have the extra controller.
                  And my bcu 8001 to 6001 can be installed on it.
                  I just need to change his dip switches.
                  I do not have his parts manuals and order number.
                  I belong to the old copier repair .
                  Mystic Crystal Revelations
                  • zuojin168
                    • Sep 2012
                    • 83
                    Thank you help me to correct grammatical errors.
                    • zuojin168
                      • Sep 2012
                      • 83
                      Don't a little way?
                      Since 8001, and 6001 print controller is look the same.There is no difference.
                      He is a SC995 now
                        • 37253
                        I gave you the parts number in my previous post. If you can not convert product codes to model numbers, you should not be working on Ricoh equipment. As we have told you with a previous thread, you cannot change a 60 page per minute machine into a 80 page machine.
                        • zuojin168
                          • Sep 2012
                          • 83
                          I this is not to change the speed.
                          And replace the controller
                          • anothertech
                            • 1759
                            I'll give the guy this much, he's persistent, but it's not going to help with what he's trying to do.
                            He asks for advice but when hes told something he does not want to hear, he just keeps asking.
                            • alexsegura27
                              • Mar 2015
                              • 10
                              HOLA SOY DE PERU ...AQUI SI CONVERTIMOS LA MP 6001 EN 8001 SI DESEAS INFORMACION ESCRIBEME ventas.amsgroup@hotmail.com
