Ricoh MPC4502
  • brodpete
    • 12
    Ricoh MPC4502
    Hi guys,
    Thanks for all your help again.
    Got a call from a customer saying, all 4 paper trays not picking up paper except from bypass tray.(Ricoh MPC4502)
    Will this be just a sensor issue or a motor fault?
    Just trying to get some thoughts before going to site as its a 4hr-drive from work.
    • 37458
    Re: Ricoh MPC4502
    Originally posted by brodpete
    Hi guys,
    Is it that all 4 trays fail to feed any paper or is that all 4 trays are jamming? If it is jamming, what is the jam code. If it is a jam and the jam code is on the error screen, point it out to the customer and tell them it would have been nice to know before you left your office so that you could bring the proper parts.
    • nmfaxman
      • 1702
      Re: Ricoh MPC4502
      Make sure she took the cover off the paper before loading it.
      Heard it happened here.
      • brodpete
        • 12
        Re: Ricoh MPC4502
        Thanks for the reply, there's no jam code on the screen. only saying paper jam but there's no paper jammed. It fails to feed paper from all trays.
          • 37458
          Re: Ricoh MPC4502
          I can see a machine not feeding from both trays 1&2 or 3&4 if a paper feed motor was bad. Two bad motors is doubtful. Check the Plotter Jam history in SP 7507. Often I have had a customer say that it is not feeding from any tray only to find out that if you pull out tray 1, tray 2 will feed.
          One other thing, the way the pick up and feed rollers are mounted on these can cause feeding problems as the pick up roller does not have its own retainer clip.
          • Zaxxon
            • 608
            Re: Ricoh MPC4502
            Hi guys,
            4 hr out 4 hr home = a full workingday! drop this customer unless its the only one You got.
            Please start you post with brand, model, problem.
            • Bantams
              • Jun 2012
              • 603
              Re: Ricoh MPC4502
              The pick up roller/belt on these are poor imo we replace all the feed rollers with the MPC2800 ones they last longer also.
              • copier tech
                • 8142
                Re: Ricoh MPC4502
                My guess would be it's not jamming from all trays, the customer is probally mistaken.
                More likely only jamming from one tray, or they have a load paper message if they're trying to print on plain or heavy paper when that type isn't in any tray etc.
