Last week I had problems with getting error code sc 524 and thru this site figured out how to reset my machine...I got the error codes a couple of times and was able to clear it. Today when I cleared using clear mode, 1-0-7-, clear stop(hold 4 sec), power down...when the machine powered back up...it took a much longer time to come back up and then defaulted to the fax feature and does not seem to know that it has a copier ...can not select the copy button, can not use document server key...it WILL print. Any ideas what to do?
I am using VISTA
I am using VISTA
