mp161 doc feed tire replacement
  • digicor
    • Jul 2008
    • 1159
    can someone please send me a diagram on how to R/R the doc feed tire on a mp161, it does not want to come off, i have tried removing the little pin that holds the gear that seems like it would release the shaft, but i cant really get it to come out, doesnt seem to me that this would be a rocket science project but it does not look like its made to be replaced, but i know it is
    thanks guys, gals
  • Elmo
    • Feb 2010
    • 541
    Re: mp161 doc feed tire replacement
    from the manual
    I Used To Live To Fix Things Now i Fix Things To Live
    • digicor
      • Jul 2008
      • 1159
      yes thank you i have this part down,its the actual feed tire on the shaft i need to c how this comes apart, there is a pin in the gear on the shaft that seems to be permanent ...
        • 37652
        It is intended to be replaced as a unit. Ricoh does not make individual parts available.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          +1
          We replace the feed assy as a whole unit.
          • Polarbear
            • Feb 2012
            • 1070
            Digicor
            Unclip the feed roller clip and pull the shaft so that the "permanent pin" moves towards the plastic frame. Now turn the shaft so that the pin lines up with the slot in the plastic frame and it can be extracted that way. Now you should have enough room to remove the roller. Re-assembly is the reverse of the above.
            Press the GREEN button!!
            • digicor
              • Jul 2008
              • 1159
              thanks thats it,
