Ricoh Aficio 2022SP
  • tcypy1961
    • 773
    Ricoh Aficio 2022SP
    Why would formatting the hard-drive on this Ricoh Aficio 2022SP fail if the hard-drive is good? Thank you for any help given.
  • rosspt
    • Mar 2012
    • 92
    Re: Ricoh Aficio 2022SP
    Format would fail if the original hdd has been replaced with one too large. Also would fail if the machine doesn't have a hdd to begin with. For this model, the hdd is an accessory.
    • Iowatech
      Not a service manager
      • 3930
      Need more input - why do you need to format the drive?
        • 37487
        A PC is much more tolerant of bad clusters than an MFP. A PC will mark a cluster bad and add it to the redirection table which lows a rather large number of redirection entries. The only sectors on a PC are critical are the boot sector and the sector that contains the primary partition table. On a MFP, the format utility merely erases the existing directory structure and write a new one. It will not tolerate any errors in the directory structure. It will also tolerate a very number of entries in the redirection table.
