MP C4500 Op panel dark...
  • Copyman2000
    • Apr 2015
    • 6
    OK so I swapped out the op panel with a known good one and it's still dark.
    Fuses on the power supply are good...
    Looking for any ideas???
  • francisco
    • Nov 2009
    • 168
    Re: MP C4500 Op panel dark...
    change laser motor and bicu
    • mikadonovan
      • May 2008
      • 2931
      Shine a flashlight into the LCD to see the sc code. If it is the polygon mirror motor, it must be replaced with the BICU at the same time, or it will happen again.
      NEVER ASSUME ANYTHING
      • ptrflrs
        Glorified Parts Swapper
        • Dec 2010
        • 192
        is that the dreaded sc202?
        jesus loves you! (everyone else thinks you're an assh*le)
        street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
        Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
        • redneckstylin
          • Sep 2011
          • 173
          log into wim via ip addy of machine sc code will be on main screen
