mp4001 finisher issue
  • digicor
    • Jul 2008
    • 1153
    I have replaced the 790 style finisher on this machine and still it works for a week or so then the same dam thing, (it has worked since i installed it 7 months ago)
    the paper stops midway through the mouth of the fin on its way to the upper tray.... I have changed the Chip to the new ,one ending in 64 on the board of the fin, same dam thing week later same dam thing
    i changed the whole board ending in 53 with one that ends in 54 with another fin that has no problems... same dam thing.... what is this?
    oh by the way, it goes to the shift tray NO PROBLEM through this whole ordeal...
    anybody have this issue and a fix??
  • zed255
    How'd ya manage that?
    • 1024
    Re: mp4001 finisher issue
    Bend the flat springs in the finisher lid to apply more pressure on the white idlers. Sounds too simple to be true, but I have seen it numerous times. The paper is just slipping on the driven rollers and not making it through in time.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Check the bridge unit door switches, their known to cause jamming issues...........................
      Mystic Crystal Revelations
      • Iowatech
        Not a service manager
        • 3930
        You might try cleaning and relubing the bushings for the rollers. If the finisher has been used for quite a while, the bushing lube hardens and causes the rollers to stall. If any of the bushings have black stuff on them that's a good bet.
        Also check the roller drive belt tension, if it is too high it can cause the rollers to stall (I did that to myself once, as I can be a dummy sometimes).
        The drive motor for those rollers is a less likely suspect for that problem, but it is still a consideration.
        Also check that the spring is on the front of the gate on the top access cover of the finisher. If that gate doesn't change position on time it can cause a problem similar to that.
        • jonhiker
          • 661
          i had this same issue. I cleaned the gray exit rollers with citrus solvent. TH\hey are on a shaft just before the finisher tray.
          • Zeldaman
            • Mar 2011
            • 946
            20150422_084920.jpg20150422_084953.jpg Hope this helps.
            Greetings...
            • Polarbear
              • Feb 2012
              • 1070
              Originally posted by Zeldaman
              [ATTACH=CONFIG]28898[/ATTACH][ATTACH=CONFIG]28899[/ATTACH] Hope this helps.
              Greetings...
              +1
              Also check the metal entrance guide (visible in the right photo above). They are soft and bend easily. If the angle is wrong or the top (swivel) part of the entrance guide is bent out of shape, it also catches the paper and slows it down.
              Press the GREEN button!!
                • 37481
                Greetings...
                Originally posted by Polarbear
                +1
                I think the fact that the jam only occurs going to the proof tray and not the shift tray rules out a problem with the entrance guide or sensor.
                • Polarbear
                  • Feb 2012
                  • 1070
                  Slimslob you have a point. Next up would be the guides and rollers in the proof tray path.
                  • digicor
                    • Jul 2008
                    • 1153
                    just a reminder, this is the second fin ive put on this 4001, and it works for a week or so then goes south.... so would the guides and rollers cause their mischief right away, and two fins same problem?
                    works for a few days then pops its malfunction head?
                    and i made sure the fin is for the 4001 series to boot..
                    • Iowatech
                      • 3930
                      Well, unless you unboxed a brand new SR790 finisher from Ricoh, yes.
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Here is just a '"odd-ball" question.
                        What is the firmware levels for both the finishers and the machine?
                        • digicor
                          • Jul 2008
                          • 1153
                          I agree, stranger things have happened, and if it has tire's or tits or gets plugged in, it will give you headache's
                          you can bet on that
                          thanks gents
                          ill look at it today and report back on the cause and cure... if there is one... LOL
                          • digicor
                            • Jul 2008
                            • 1153
                            And the winner is!
                            the tires and the springs in this quote were the problem, How bout that! the tires were coated with dirt and the white guide rollers had very little tension on them,
                            I cleaned the tires, and brushed them a little with a wire brush, and re bent the guide roller spring arms, and it ran like a cheetah...chasing cheese doodles!
                            Thanks for all the posts
