Savin C9025 SC565
  • KapeKopyTek
    • Nov 2013
    • 285
    Savin C9025 SC565
    C 18389, BW 156549, reset SC 565 OK, coded again in a few minutes. Goose says p/r lamp or PSU. Ohmed out lamp ok, checked thermostats. Found p/r thermostat tripped, reset ok, machine up and running. Many broken teeth on duplex reverse gate pawl D0394588, ordering. Machine is not on a surge protector, urged customer to consider.
  • tufbnme
    • 493
    Re: Savin C9025 SC565
    [Symptom]
    SC573 (Pressure roller overheat 4 (software error)) is displayed. After resetting the SC573, the machine operates normally only for a certain time, then SC565 (Pressure roller fusing lamp consecutive full power 3) is displayed next.
    Note:
    After resetting the SC573, the machine operates normally. But after 5 minutes, SC565 is displayed. After resetting the SC565, the machine operates normally for 5 minutes.
    SC573: The detected pressure roller temperature stays at 230�C or more for 1 second.
    SC565: When the fusing unit is not running in the ready condition, the pressure roller fusing lamp keeps ON full power for 250 seconds or more.
    [Cause]
    The pressure roller thermostat or pressure roller heater is disconnected.
    [Solution]
    Replace the pressure roller thermostat or pressure roller heater.
    Note:
    Because the machine can operate for 5 minutes after reloading, you can change the AOF setting to 1 minute as a temporary workaround. (Be sure to replace the part when it is delivered to you.)
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Pressure roller heat detection is via two contact type thermistors (centre/end).
      I would check they are not dirty / out of position / faulty (temp display SP1106-003/004).
      A incorrect low temp reading could lead to overheating and hence a hard thermostat blow.
